Thank you very much Ben, i appreciate your work and time
I will check it later, and this will be very useful
I checked it and it work excellent but it can’t be moved, that’s why i used two columns and one row and the first square is hidden, i will try to use your solution with the previous code
Maybe a long press to move the component, i don’t know if that possible
right, I didn’t realize that. At the moment you can group it and move like this.
In the meanwhile I’ll try to change that.
Thank you i will check it , to learn more and to make changes if i can.
> protected override void Layout()
> //Lock this object to the pixel grid.
> //I.e., do not allow it to be position in between pixels.
> Pivot = GH_Convert.ToPoint(Pivot);
> Bounds = new RectangleF(Pivot, new SizeF(ButtonSize*2, ButtonSize));
> private Rectangle Button()
> int x = Convert.ToInt32(Pivot.X);
> int y = Convert.ToInt32(Pivot.Y);
> return new Rectangle(x+ButtonSize, y, ButtonSize, ButtonSize);
if you change like this, there will be a (sadly) transparent zone left of the button where you can grab the button and move it. I’d love to investigate further, but this will take some time and learning efforts
B
Guys, this discussion is really interesting.
I didn’t have time to test your code, but i bookmarked it and i will study it all once i have time.
Raw idea: flip the switch on the release of the button/click.
Click-press > save current click XY canvas coordinate, but let the component behave normally (it should be draggable/moveable)
Click-release > check, if current XY are equal than old XY, flip the switch.
Visual studio is a nightmares always freeze and force closed, i will check the code and try later.
Thanks Riccardo, i don’t have experience to do that with c#, but i wil, try
A little change in the code but still the problem of moving, i try to use MouseButtons.Right but the problem that the context menu appears
using System;
using System.Collections.Generic;
using Grasshopper.Kernel;
using System.Drawing;
using Grasshopper.GUI;
using Grasshopper.GUI.Canvas;
using Grasshopper.Kernel.Types;
namespace singleClick //adapt to your project
public class SpecialIntegerObject : GH_Param<GH_Boolean>
public SpecialIntegerObject() :
base(new GH_InstanceDescription("Toggle", "Toggle", "True/False", "Params", "Input"))
public override void CreateAttributes()
m_attributes = new SpecialIntegerAttributes(this);
protected override Bitmap Icon
get
//return toggleone.Properties.Resources.toggle;
return null;
public override GH_Exposure Exposure
get
return GH_Exposure.primary | GH_Exposure.obscure;
public override System.Guid ComponentGuid
get { return new Guid("{520F0976-35D1-4CC4-925B-2A07BFF17007}"); }
//private int m_value;
private bool m_value;
public bool Value
get { return m_value; }
set { m_value = value; }
protected override void CollectVolatileData_Custom()
VolatileData.Clear();
AddVolatileData(new Grasshopper.Kernel.Data.GH_Path(0), 0, new GH_Boolean(Value));
public override bool Write(GH_IO.Serialization.GH_IWriter writer)
writer.SetBoolean("SpecialInteger", m_value);
return base.Write(writer);
public override bool Read(GH_IO.Serialization.GH_IReader reader)
reader.TryGetBoolean("SpecialInteger", ref m_value);
return base.Read(reader);
public class SpecialIntegerAttributes : GH_Attributes<SpecialIntegerObject>
public SpecialIntegerAttributes(SpecialIntegerObject owner)
: base(owner)
public override bool HasInputGrip { get { return false; } }
public override bool HasOutputGrip { get { return true; } }
private const int ButtonSize = 32;
public bool bo;
//Our object is always the same size, but it needs to be anchored to the pivot.
/// <summary>
/// This method returns the button at the given column and row offsets.
/// </summary>
return new Rectangle(x, y, ButtonSize*2, ButtonSize);
/// <summary>
/// Gets the value for the given button.
/// </summary>
public override GH_ObjectResponse RespondToMouseDown(GH_Canvas sender, GH_CanvasMouseEvent e)
//On one click we'll set the owner value.
if (e.Button == System.Windows.Forms.MouseButtons.Left)
bo = !bo;
RectangleF button = Button();
if (button.Contains(e.CanvasLocation))
Owner.RecordUndoEvent("Square Change");
Owner.Value = bo;
Owner.ExpireSolution(true);
return GH_ObjectResponse.Handled;
return base.RespondToMouseDown(sender, e);
public override void SetupTooltip(PointF point, GH_TooltipDisplayEventArgs e)
base.SetupTooltip(point, e);
e.Description = "Toggle";
/// <summary>
/// This object is rendered as a 1x3 grid of capsules.
/// </summary>
protected override void Render(GH_Canvas canvas, Graphics graphics, GH_CanvasChannel channel)
if (channel == GH_CanvasChannel.Objects)
//Render output grip.
GH_CapsuleRenderEngine.RenderOutputGrip(graphics, canvas.Viewport.Zoom, OutputGrip, true);
//Render capsules.
Rectangle button = Button();
GH_Palette palette ;
if (bo)
palette = GH_Palette.Blue;
else
palette = GH_Palette.White;
GH_Capsule capsule = GH_Capsule.CreateTextCapsule(button, button, palette, bo.ToString(), 4, 4);
capsule.Render(graphics, Selected, Owner.Locked, false);
capsule.Dispose();
nice, I took your code and added the things I’ve learned:
here’s the code:
using System;
get
return null;
get
public bool Value
: base(owner)
public bool bo;
Bounds = new RectangleF(Pivot, new SizeF(ButtonSize * 4, ButtonSize));
/// <summary>
/// </summary>
return new Rectangle(x+3*ButtonSize, y+2, ButtonSize-2 , ButtonSize-4);
/// <summary>
/// </summary>
bo = !bo;
Owner.Value = bo;
/// <summary>
/// </summary>
//Render capsules.
GH_PaletteStyle style = GH_Skin.palette_normal_standard;
GH_Skin.palette_normal_standard = style;
base.Render(canvas, graphics, channel);
/*if (bo)
palette = GH_Palette.Black;
else
GH_Palette palette = GH_Palette.Black;
capsule.Dispose();
though, I have absolutely no idea why the heck this thing is blue…haha
Thank you , very nice.
I did similar thing based on an old code of David from the old forum.
I tried to move the circle to the left side but i don’t understand exactly the logic and i hope someone can make the circular button like radio button with two options white and green for example, and the component moved from the other area.
I hope also that Mcneel developers make their own software to create components with button designer like windows form. and the developer can test it directly in Grasshopper.
And this is the code
Two cjhoices better than one
Also i need to fix the problem with the circular button, it change the text but not the output.
using System;
get
return null;
get
public bool Value
: base(owner)
public Image on_image;
public Image off_image;
public bool bo;
//new lines -----------------------------------------------------------------
base.Layout();
Rectangle rec0 = GH_Convert.ToRectangle(Bounds);
rec0.Width += 32;
Rectangle rec1 = rec0;
rec1.X = rec0.Left + 64;
rec1.Width = 32;
rec1.Inflate(-2, -2);
Bounds = rec0;
ButtonBounds = rec1;
/// <summary>
/// </summary>
/// <summary>
/// </summary>
/// <summary>
/// </summary>
private Rectangle ButtonBounds { get; set; }
//Render capsules.
if (bo)
else
GH_Capsule capsule = GH_Capsule.CreateTextCapsule(button, button, palette, bo.ToString(), 8, 8);
GH_Capsule buttonb = GH_Capsule.CreateTextCapsule(ButtonBounds, ButtonBounds, GH_Palette.Black, "", 16, 16);
buttonb.Render(graphics, Selected, Owner.Locked, false);
buttonb.Dispose();
bo = !bo;
Owner.Value = bo;
this should fix the black button issue:
though, I’m not sure it will be beatuiful to change the position of the button, as the connection point will float in space.
Yes this fix the problem thank you.
You are about OutputGrip this also should fixed when move the circular button, maybe by change rec0.X
It work fine now, is there a way to use custom color (like green) in GH_Palette?
Thank you very much @benedict for your help.
And how to avoid these white edges?
as it is connected to the pivot position, I guess it’s simpler to draw them both and switch between the buttons that are passed to the render override. that would be my guess. this would also allow you to easily switch between colors (like green) for the GH_Palette palette value.
I allow myself to tag @DavidRutten for this question. I’m sorry David, I tried like two nights to understand why this renders out blue, but no success. I tried the changes from Custome Node Color? - #6 by DavidRutten but had no success. There must be a ton of useless snippets in the code and I understand a little more every day, but this blue canvas thing is driving me nuts!
is it correct that I need to render the canvas with base.Render and all the elements (in this case a button only) on the canvas with capsules?
thank you
Ben
Thank you Ben, sadly visual basic always freeze and i can’t even modify one line.
I find another example of David and look simple and maybe better.
using System;
using Grasshopper.Kernel.Attributes;
using GH_IO.Serialization;
namespace Testing
public class SuperDuperComponentAtteributes : GH_ComponentAttributes
public SuperDuperComponentAtteributes(SuperDuperComponent owner)
: base(owner)
private RectangleF _baseBounds;
private RectangleF _thisBounds;
private RectangleF _buttonBounds;
base.Layout();
_baseBounds = Bounds;
_buttonBounds = Bounds;
_buttonBounds.Y = Bounds.Bottom + 10;
_buttonBounds.Height = 32;
_thisBounds = RectangleF.Union(_baseBounds, _buttonBounds);
// Overwrite the Bounds property to include our external button.
Bounds = _thisBounds;
// Re-instate the Bounds computed by the base class Layout method.
// But only during calls to the base class.
Bounds = _baseBounds;
string text;
if ((Owner as SuperDuperComponent).MinMax)
text = "MinMax";
else
text = "MaxMin";
GH_Capsule button = GH_Capsule.CreateTextCapsule(_buttonBounds, _buttonBounds, GH_Palette.Pink, text);
button.Render(graphics, Selected, Owner.Locked, Owner.Hidden);
public override GH_ObjectResponse RespondToMouseDoubleClick(GH_Canvas sender, GH_CanvasMouseEvent e)
if (_buttonBounds.Contains(e.CanvasLocation))
// If the double-click happened on our button, we need to handle the event.
SuperDuperComponent sd = Owner as SuperDuperComponent;
if (sd == null)
return GH_ObjectResponse.Ignore;
sd.RecordUndoEvent("MinMax toggle");
sd.MinMax = !sd.MinMax;
sd.ExpireSolution(true);
// If not, we need to let the base class handle the event.
// Just to make sure the base class doesn't get confused, we should once again
// pretend that the Bounds are as expected.
GH_ObjectResponse rc = base.RespondToMouseDoubleClick(sender, e);
return rc;
public class SuperDuperComponent : GH_Component
public SuperDuperComponent()
: base("Super Duper", "SupDup", "Tinned awesomeness, consume before 6/2018", "Test", "Test")
MinMax = true;
m_attributes = new SuperDuperComponentAtteributes(this);
public static readonly Guid SuperDuperId = new Guid("{0CD86E8B-FA36-47A5-9D71-9C678F96B13A}");
public override Guid ComponentGuid
get { return SuperDuperId; }
get { return GH_Exposure.primary; }
/// <summary>
/// Gets or sets whether the logic ought to be MinMax or MaxMin.
/// </summary>
public bool MinMax { get; set; }
protected override void RegisterInputParams(GH_InputParamManager pManager)
pManager.AddIntegerParameter("Gary", "G", "Who the man?", GH_ParamAccess.item);
pManager.AddIntegerParameter("Cooper", "C", "Damn right!", GH_ParamAccess.item);
protected override void RegisterOutputParams(GH_OutputParamManager pManager)
pManager.AddIntegerParameter("Super", "S", "Million dollar trooper", GH_ParamAccess.item);
pManager.AddIntegerParameter("Duper", "D", "Puttin' on the Ritz", GH_ParamAccess.item);
protected override void SolveInstance(IGH_DataAccess DA)
int a = 0;
int b = 0;
if (!DA.GetData(0, ref a)) return;
if (!DA.GetData(1, ref b)) return;
if (MinMax)
DA.SetData(0, Math.Min(a, b));
DA.SetData(1, Math.Max(a, b));
else
DA.SetData(0, Math.Max(a, b));
DA.SetData(1, Math.Min(a, b));
public override bool Write(GH_IWriter writer)
writer.SetBoolean("MinMax", MinMax);
public override bool Read(GH_IReader reader)
MinMax = reader.GetBoolean("MinMax");
Fologram addon have an option to add a small button to the component to synchronize, how we can do this?
Maybe this help to add a similar button to the slider with two inputs to change minimum and maximum values.
This code from the old forum to create radio button, how we can use it instead of the red button?
private void DrawRadioButton(Graphics graphics, PointF center, bool checked)
if (checked) {
graphics.FillEllipse(Brushes.Black, center.X-6, center.Y-6, 12, 12);
else
graphics.FillEllipse(Brushes.White, center.X-4, center.Y-4, 8, 8);
thank you very much @anon39580149 , this looks indeed very interesting! I sadly have to put this aside for a while, my clients start to be unpatient with me spending time in code learning, haha. However, this example provides again many enlightments to me, and adding these overrides opens a bunch of new universes to me:-) thank you, really! I strongly appreciate this exchange!!
have a good start for the week
Ben
