Hi
Is there a way to automatically click a button every certain period of time ? I tried adding timer but is not working.
A problem with buttons is that they generate two “events” instead of just one, as usually desired. (OnMouseDown and OnMouseUp)
You might want to look at this thread:
There can be problems when you have two or more timers in a single GH file.
Thank you !
In case it isn’t obvious, the output of those Counter components will have the same effect as a button on downstream components, except that you get only one event on each interval instead of two.
counter_2020Mar4a.gh (7.9 KB)
You can stick a not gate at the end of course to hit ‘true’ when the counter returns to zero.
Counter.gh (3.8 KB)
Thanks a lot!
