I’ve never had to make something like this before. I tried making a 1’ dia cylinder, creating a spiral using the Helix command and subtracting the cylinder from the spiral. However, I can’t get the vertical span of the helix correct. I tried adjusting the pitch but it’s still not right. I’m thinking there is some ratio that I need to know as opposed to guess work.
Hello - that looks like it probably has four’pipes’, on a much looser helix. Use History on the Pipe, and History on ArrayPolar, then scale the helix curve vertically until it all looks correct.
Thanks Pascal. I didn’t realize it was 4 pipes. I assumed 1 like wrapping string ona a handle. I now got something that looks close. Still guessing but it will work. I suspect there is a ratio of some sort, but no idea where to start looking for it.
