Hi there.
I was working on some conceptual renderings using roof tiles. I have the material set up as PBR, but displacement as a property of the object using the bitmap (actually I have to mention that I was not able to make displacement to work with when included in the material propoerties). This workaround works fine, But then.. when Thickening to the surface, it misbehaves if I switch it to Solid (i mean it does the thing, but it offsets the completely opposite direction the “second face”..
What I’d like to suggest is that the Thickening feature should have an additional option in “solid”, where the offset is calculated after the mesh has been displaced.
