As shown in the image, this curve fails when using the Pipe command. I came up with a solution, which is to reparameterize the curve, and then the Pipe command works successfully. What is strange is that the parameter distribution of the curve is displayed differently in Grasshopper and Rhino. Which parameter distribution is correct? What is the reason for the Pipe command failure?thank you,everyone
It is with regret that we inform you that you are using a pirated license . If you purchased from one of our authorized dealers, please contact the dealer to reclaim your rightful legitimate license, and we will assist accordingly. If you obtained it through other channels, please uninstall it, and then you can contact your nearest dealer for a purchase discussion at the website below
Reminder and Call to Action: Respecting intellectual property starts with rejecting pirated software. Don’t wait until your own designs and intellectual works are plagiarized, stolen, misused, or copied to think about protecting intellectual property rights. Maintaining a good intellectual property environment requires your participation
It’s really strange, it doesn’t work in both Rhino 7 and Rhino 8. I’ve asked others, and they couldn’t get it to work either. Also, if you look at its parameter distribution, there seems to be an issue. The curve is supposed to be non-rational, but it’s displayed as a rational curve
