My computer has two identical screens connected, and the GH2 window will only open when a specific screen is set as the home screen. Otherwise, it will just stay on the Rhino interface and you won’t be able to find the GH2 window.
I have used 2 screens for a long time with no problem at all. My secondary is a 4K horizontal and primary is UHF vertical (because most of my designs are more vertical than horizontal.) I put Rhino on the secondary screen and GH on the primary and have never had a problem. All this is on a Windows 11 machine - not Windows 10.
But I run GH1 - so perhaps you have found a bug in GH2. I haven’t tried GH2 because I didn’t think it was ready for real work - but maybe it is.
I can test tomorrow at the office (I have windows with 2 screens there as well), but when you say “stay on the Rhino interface” what exactly does that mean?
Except for the gh2 window not popping up, there is nothing abnormal, that is, you can only see the Rhino window.
I’ve been switching back and forth but can’t seem to repeat the problem. Still, I’ll add some code which ensures that when GH2 is first shown it is limited to the current screen regions.
Thanks!I will continue to test when have a new version.
New version (made for Rhino 8.3) should be out now.
Problem solved! thank you!
