The Gumball Problem
        protected override void OnMouseDown(Rhino.Input.Custom.GetPointMouseEventArgs e)
            starting_point = e.Point;
            //RhinoApp.WriteLine($"测试打印,{starting_point}");
            if (m_dc.PickResult.Mode != Rhino.UI.Gumball.GumballMode.None)
                return; // 如果 Gumball 已经被选中,不做处理
            m_dc.PickResult.SetToDefault(); // 重置拾取结果
            // 构造一个拾取上下文
            Rhino.Input.Custom.PickContext pick_context = new Rhino.Input.Custom.PickContext();
            pick_context.View = e.Viewport.ParentView;               // 设置当前视图
            pick_context.PickStyle = Rhino.Input.Custom.PickStyle.PointPick; // 点选模式
            // 获取拾取变换矩阵
            var xform = e.Viewport.GetPickTransform(e.WindowPoint);
            pick_context.SetPickTransform(xform);
            // 获取射线(视锥线)
            Rhino.Geometry.Line pick_line;
            e.Viewport.GetFrustumLine(e.WindowPoint.X, e.WindowPoint.Y, out pick_line);
            pick_context.PickLine = pick_line; // 设置拾取线
            pick_context.UpdateClippingPlanes(); // 更新裁剪平面
            //检测是否选中了 Gumball,如果选中则更新约束
            m_dc.PickGumball(pick_context, this);
            st_bool = true;
            base.OnMouseDown(e);
When using rays to determine whether Gumball is selected, errors always occur in the perspective view. This has been bothering me. Is there a better way to solve this problem?
