Dear Sir/Madam:
I have just test a C++ sample SampleSplitCurve and it runs well. But I am very confused about the data structure of ON_SimpleArray crv_t. After adding a line in the code, the output result is the same. For example I spilt a line for (1,1,0) to (1,11,0). The output is 0,2,4. Would you please explain me the problem and how to print the correct result of crv_t?
Many Thanks,
Meng
// The one and only CCommandSampleSplitCurve object
static class CCommandSampleSplitCurve theSampleSplitCurveCommand;
CRhinoCommand::result CCommandSampleSplitCurve::RunCommand(const CRhinoCommandContext& context)
CRhinoGetObject go;
go.SetCommandPrompt(L"Select curve to split");
go.SetGeometryFilter(CRhinoGetObject::curve_object);
go.GetObjects(1, 1);
if (go.CommandResult() != CRhinoCommand::success)
return go.CommandResult();
const CRhinoObjRef& crv_obj_ref = go.Object(0);
const CRhinoObject* crv_obj = crv_obj_ref.Object();
const ON_Curve* crv = crv_obj_ref.Curve();
if (0 == crv_obj || 0 == crv)
return CRhinoCommand::failure;
ON_SimpleArray crv_t;
CRhinoCommand::result rc = PickCurveParameters(context.m_doc, *crv, crv_t);
if (rc != CRhinoCommand::success)
return rc;
ON_3dmObjectAttributes atts(crv_obj->Attributes());
int i;
for (i = 0; i < crv_t.Count() - 1; i++)
RhinoApp().Print(L"Point = %f,%f,%f\n", crv_t[i,0], crv_t[i,1], crv_t[i,2]);
ON_Interval interval(crv_t[i], crv_t[i + 1]);
if (crv->Domain().Includes(interval))
ON_Curve* new_crv = ON_TrimCurve(crv, interval);
if (new_crv)
CRhinoCurveObject new_crv_obj = new CRhinoCurveObject(atts);
new_crv_obj->SetCurve(new_crv);
context.m_doc.AddObject(new_crv_obj);
context.m_doc.DeleteObject(crv_obj_ref);
context.m_doc.Redraw();
return CRhinoCommand::success;
CRhinoCommand::result CCommandSampleSplitCurve::PickCurveParameters(CRhinoDoc& doc, const ON_Curve& crv, ON_SimpleArray& crv_t)
crv_t.Empty();
CRhinoGetCurvePoints gp;
gp.Constrain(crv);
int l_option = gp.AddCommandOption(RHCMDOPTNAME(L"Length"));
/int s_option =/ gp.AddCommandOption(RHCMDOPTNAME(L"Segments"));
CRhinoGet::result res = gp.GetPoints();
if (res == CRhinoGet::option)
const CRhinoCommandOption* option = gp.Option();
if (0 == option)
if (option->m_option_index == l_option)
return DivideCurveLength(doc, crv, crv_t);
else
return DivideCurveSegments(doc, crv, crv_t);
else if (res != CRhinoGet::point)
return CRhinoCommand::cancel;
ON_3dPointArray points;
int i, point_count = gp.Points(points);
for (i = 0; i < point_count; i++)
double t = 0;
if (crv.GetClosestPoint(points[i], &t))
crv_t.Append(t);
crv_t.Append(crv.Domain().Min());
crv_t.Append(crv.Domain().Max());
crv_t.QuickSort(&ON_CompareIncreasing);
