CRhinoGetObjec API question
hi there still bugging on a simple issue…
Why a simple CRhinoGetObject does’ not work while the same code with CRhinoGetPoint work like a charm ? it’s me or the API is bugged ?
( what i want is to select a step by step CRhinoGetObject in controlled order …)
please i need a quick look is it just an API issue ?
My needed Not working Code:
CRhinoGetObject* go;
int ct = 0;
while (ct < 2) {
	for (size_t i = 0; i < NumberOfPoint; i++)
		go = new CRhinoGetObject();
		str.Format(L"Select the point number %d in row:%d\r\n", i + 1, ct + 1);
		go->SetCommandPrompt(str);
		go->SetGeometryFilter(CRhinoGetObject::meshvertex_filter);
		CRhinoGetObject::result res = go->GetObjects(0, 1);
		if (go->CommandResult() == CRhinoCommand::success) {
		ON_3dPoint* pt;
		if (ct == 1) {
			listpt[i + NumberOfPoint] = go->Point();// i + NumberOfPoint shift the index for storage.
			pt = &(listpt[i + NumberOfPoint]);
		else {
			listpt[i] = go->Point();
			pt = &(listpt[i]);
		go->ClearObjects(); // ...
		delete go;
		str.Format(L"(%lf,%lf,%lf)\r\n", pt->x, pt->y, pt->z);
		RhinoApp().Print(str);
		else {
			return CRhinoCommand::failure;
	ct++;
Now my full sample Working Code (but not quite why i need):
CRhinoCommand::result CCommandaTest::RunCommand(const CRhinoCommandContext& context)
	size_t start = 0;
	ON_3dPoint listpt[20];
	CRhinoObjRef obj[20];
	for (size_t i = 0; i < 20; i++)
		listpt[i] = ON_3dPoint(0, 0, 0);
	int NumberOfPoint = 0;
	ON_wString str;
	CRhinoGetNumber gn;
	gn.SetCommandPrompt(L"Set the number of points for One Row:\r\n");
	gn.GetNumber();
	NumberOfPoint = (int)gn.Number();
	str.Format(L"The Number: %d\r\n", NumberOfPoint);
	CRhinoGetPoint gp;
	int ct = 0;
	while (ct < 2) {
			gp.SetCommandPrompt(str);
			gp.GetPoint();
			ON_3dPoint* pt;
			if (ct == 1) {
				listpt[i + NumberOfPoint] = gp.Point();
			else {
				listpt[i] = gp.Point();
				pt = &(listpt[i]);
		ct++;
	// Count[0] + Count[1] + Count[2]
		str.Format(L"Memory slot: %d 3d point collected %lf %lf %lf\r\n", i, listpt[i].x, listpt[i].y, listpt[i].z);
	return CRhinoCommand::success;
issue fixed with these two class method.
CRhinoGetObject::EnablePreSelect();
CRhinoGetObject::EnablePostSelect();
regards.
