Im getting a consistent way to crash rhino in such a way that it shuts down my w10 PC without fault. No BSOD, no dump, cpu temp normal.
I thought it was GH, but i managed to corner it down to just rendering a geometry. Textures dont matter, just final draft quality, large sized objects and large render.
I updated the nvidia, cpu drivers, etc, same result. it’s not just with one file, but any high render settings.
If go to the render panel, set to final quality, press the render button at the bottom right. last render 3000x2000 was 13% done when it crashed.
After resetting the render panel, i believe it’s the environment or lighting was causing the issue.
i dont have other pc’s to test this on. But i do have models that had those settings - not sure i want to retry though…
I there a way to dump the memory that’s preferred?
i did go to “tech support” but didn’t see a relevant “post issue”, open ticket, only upload a file that fitted the need. I also saw some crash oriented posts, none helped, and hope some can guide me. Not sure this is the right place to dump sysinfos etc…
Assuming you are using Rhino 6 please start by copy/pasting the text from the Rhino command _SystemInfo.
If you want to share the 3dm file confidentially you can use rhino3d.com/upload?to=nathan@mcneel.com . when the upload is completed I’ll receive an automated notification the file has been uploaded. Since tech support can see these files as well it would be a good thing to copy the URL to this topic in the comments section for the upload as well.
Here’s the file, i select the handle and blade with the texture. The render settings seem right. Sorry, i lost the ‘default’ that was causing the issue and this is the render setting that got me in trouble… I’ll try to cause a crash to nail the model (after GH finishes its grasshopping).
Not sure what you want to select in your attached file. You say the plane with picture material and then one of the handles? And rendering at 3000x2000 causes crash with Rhino Render at Final Quality in Rhino v6?
There’s a knife blade with a mapping, a hexagonal red and black handle. Might be hidden and those are the parts. The other parts are construction steps. But you got the parts right.
