I’m new to Rhino (30 years on CAD). Is there a way to add a texture to lines or do you have to create a solid or surface for each line? I’m rendering a goban (GO Board) with a grid of lines. The grid will show in the Rendered View mode, but not when rendered. I realize this is a basic knowledge level but everyone starts somewhere. ![]()
If you use Raytraced you can set in the display settings to draw curves
When using Rhino Render then in the post effects enable curves
Great Nathan, I will give it a shot tomorrow! Thank you.
