I’m working on a Grasshopper application that could benefit from the ability to display line segments with texture. Is there a way to do this within the context of the Grasshopper development environment?
Related idea: OpenGL supports textured line segments… is OpenGL accessible from within DrawViewportMeshes? (Back in the day we used to use OpenGL commands within a C++ display conduit to render auxiliary geometry alongside Rhino’s display.)
Mmm, don’t you mean line shaped meshes with texture? In that case, yes, you can texture the meshes. A line simply can’t have texture bc is 1d and if you’re referring to a continuity pattern I think you have to trim the line and just draw what you’re interested in.
No, I want to draw lines on the screen with color defined by a texture image. In OpenGL, texture coordinates can be associated with the vertices of a line and the graphics system selects the display color by sampling the texture image between the texture coordinates.
As an alternative, I can convert my line segments to quad meshes with texture coordinates. But that will double the (already excessive) number of vertices.
