Texture section missing in Rhino material editor?
Hi, I’m using Rhino’s default renderer and trying to edit a material, but I don’t see a Textures section in the material editor.
The only menus showing are:
  • Name and Type
  • Physically Based Material
  • Bump / Normal and Displacement
  • Notes
Shouldn’t there also be a Textures section (with options like color texture, roughness, etc.)?
I’m not sure if this is a bug, a display issue, or if I’m doing something wrong.
Any help would be appreciated!
Instead of trying to edit the material through this view open the Materials panel and set it to tree view. I find that easier to work with since you can more clearly see what textures are used by a material.
