Dear Rhino Developers,
I’m encountering a critical compatibility issue between Rhino 7.0 and 8.0, and would greatly appreciate your expertise.
Problem Summary:
- Preconditions: Material and texture axes are properly configured before execution.
- Project Constraint: I can ONLY modify the mesh’s
m_Ttexture coordinate array . - Rhino 7.0: Directly modifying
m_T(see code below) successfully updates texture display. - Rhino 8.0: Identical code executes without errors, but no visual changes to texture.
Code Snippet (Working in 7.0, Failing in 8.0):
const CRhinoMeshObject* mesh_obj = CRhinoMeshObject::Cast(ob);
if (mesh_obj)
const ON_Mesh* mesh = mesh_obj->Mesh();
if (mesh)
ON_Mesh* copy_mesh = mesh->Duplicate();
if (copy_mesh)
for (int i = 0; i < copy_mesh->m_T.Count(); i++)
ON_2fPoint pt(copy_mesh->m_T[i].x * 1.5, copy_mesh->m_T[i].y * 2);
copy_mesh->m_T[i] = pt;
RhinoApp().ActiveDoc()->ReplaceObject(mesh_obj, *copy_mesh);
Best regards,
Ye
