On the above attached grasshopper, where meshes are internalized, I just select the Group and use Ctrl+Space to bake.
The default shortcut is the Insertkey.
Interesting how the behavior isnāt present when right clicking the Group component and baking.
Very quirky, thanks for reporting RH-87987
Thank you for testing on your end.
Would be nice if fixed.
I assigned the youtrack to David but its going to be low priority, perhaps @kike or @AndyPayne can take a look at what it would take to resolve.
This bug can spiral pretty bad, because the Atrribute User Text is so large that it makes the file become like 50GBā¦
agreed, but as far as i can tell its only going to happen if you have an invalid mesh and are using the keyboard shortcut to bake, which isnāt a common scenario.
Not necessarly.
Take this case for example:
Testing different kinds of geometry, for design, using FlowAlongCurve in grasshopper, will most likely create bad meshes.
FlowAlongCurve is best to be used with meshes since surfaces become too heavy to compute. Thatās because this component doesnāt have an option to preserve structure of NURBS.
So, for fast testing, 50-100 meshes will most likely be grouped for baking in Grasshopperā¦
And if Crtl+Space is used to bake ā¦
@Japhy , same thing happens when you use Right-Click bake
Adding the 1.5 million length user text?
Not seeing it here in another test of your file.
250613 badmesh.gh (940.3 KB)
Try baking these meshes using right-click,
You should get a large user text.
large attrib user text.gh (50.4 KB)
First bake using Ctrl+Space, Then, Undo, And use RightClick to bake again.
Thanks, letās see what the devs come up with.
Perhaps related to this topic:
Ah yeah, glad Iām not the only one reporting this.
Thanks, iāll switch this from David to Kike, the previous fix didnāt account for this scenario it looks like.
