I have a csv. file which I have simplified with a single column of data containing 11 numerical data inputs (floats). I want to display these 11 pieces of data on 11 points along a line.
Why does it display the index rather than the paths?
You pluged a series of numbers into the text tag…just plug the output of your frame into the text tag and you will see what you want.
Your points output to location input of the text tag.
Your csv column output to the text input of the text tag.
Any other node in your setup makes not much sense to me.
Except the color and size
