Text Tag 3d not working in WIP/GH BUG!
I get the following error message:
“1. Solution exception:Der Einstiegspunkt “CRhinoAnnotationText_New” wurde nicht in der DLL “rhcommon_c” gefunden”
In Rhino 5 …it works ???
The underlying annotation classes were recently changed. Grasshopper hasn’t caught up yet.
The only dll accessing rhcommon_c.dll is RhinoCommon.dll, so this must be some mismatch in RhinoCommon SDK. @stevebaer ?
Yes, it is a bug that we still need to fix. The bug is on my list at
https://mcneel.myjetbrains.com/youtrack/issue/RH-38000
RH-38000 is fixed in the latest WIP
yes, it works now. Thank you.
In the latest build 6.0.17164.11481 text tag 3D doesn’t work again :frowning:
1. Solution exception:Object reference not set to an instance of an object.
On the other hand the new custom preview component is soooo good :slight_smile: @DavidRutten
Yep, I can repeat that. Something amiss with the text drawing. Official bug report.
This has been fixed. Please let me know if it works again in your most recent Rhino WIP.
Yes yes sorry it works perfectly :slight_smile:
