Text Function: Detail Scale
I’m new to Rhino 8 running a trial and trying to grasp dynamic text for annotations in a layout. Things like blocks and functions are new to me.
I’d like to be able to insert a smart label like below into future drawings and have the scale text adjust to each specific detail (viewport) I link it to. Right now I’m setting it up manually through the function dialogue for each respective text/view.
Can this be streamlined? Is there any documentation on the setup process?
Hi Thomas -
I’m not sure if that means that you are using a block for this or if you are copying and editing a previous label each time. Either way, you need to go through the function dialog to select the text field and the detail, but using a block might speed up the process somewhat. When you insert a new block instance, you’d get a dialog like this and need to hit fx to select the text field and detail:
Hi Wim,
I wasn’t using a block at first, but now am.
Working in a blank file I’ve:
  1. drawn the label geometry
  2. added text
  3. converted text to a block attribute (a command I just learned)
  4. and lastly turned the geometry and text/attributes into a single block.
I can now insert an instance of the block and get the attribute prompt for ‘detail scale” and the rest of the parameters. This is exactly what I was looking to do.
Thanks!
