Where is the Text box ? i normally type text , then a dialog appears and i can put in … text , now a dialog appears and i can not do anything ? where is it
latest update btw
Have you tried pulling the bottom of the dialog downward to see if a text box becomes visible? I know there was a bug to this effect - the dialog does not look resizable, but it is…
Bummer thats it , anoying …
Thanks had not think of that , and it was there always…
Do you have the latest service release? I don’t know if/when the bug got fixed… It also might be that doing that once is all you need, it will remember for the next time…
yes latest update that did not show the text field , but problem solved now
