Jim-
THANKS ! THIS makes a HUGE potential difference. I’ll check it out and get back to you, but am expecting success.
So- let’s be clear - in a CLOSED POLYSURFACE use filletsrf instead.
Thanks again -
CFee.
Jim-
Thanks again -
CFee.
Hi Jim
Very clear explanation, as usual.
This is the kind of info that many new users need IMO.
I agree that it would be fine if FilletSrf were able to handle spherical fillets.
Still I would be glad if the command Chuck told us about
appeared as a new command. ( Independently from FilletSrf )
I also see it as another way to build spheres ( trimmed or not ), that can be useful in itself.
One more tool in that nice toolbox called Rhino.
What do you think ?
Cheers
Yes I agree completely that a command that builds a sphere of a given radius that is tangent to 3 surfaces would be useful.
What I object to is the claim that this new command addresses a serious bug in the filletSrf command. What it really does is make that bug even more entrenched and even less likely to ever be fixed correctly.
If a user is using the FilletSrf command and makes a fillet that ends where it runs into another fillet of the same size that user should be able to treat that surface like any other surface and make 2 clicks to create the next fillet in the string and then move on to the next fillet. The user shouldn’t be told “FilletSrf failed to create fillets” . And now that the code has been written to make that fillet in that situation it seems perfectly reasonable to expect it will be used.
Two thumbs up Jim
Hi jim, I’m having trouble locating that claim. Would that be from a McNeel person? Is it in this thread?
hi pascal, i am not very sure but i believe it derived out of those 2 comments.
so basically you are even a part of it
Yes.
are you going to lose your job now?
thinking about it, wouldn’t it be manageable that the ui with this regular little pop up window could address many different commands and it just gets an extra check for this and voila its in one command? all those test commands which nobody knows of… even if they dont work fully but in a wip 6 at least they could appear at least close to where they belong. i mean i wish this for the mac version then.
For what, again? I’m still looking for the claim.
I have explained this several times…
When the user is running filletSrf and clicks on a surface that is a fillet
of the same radius and another surface the user gets the response “FilletSrf failed to create fillets” That’s a bug. Whether or not anyone at McNeel is honest enough to admit it - It is still a bug.
There is no excuse for filletSrf to fail to create the requested fillet as long as the surfaces are close enough so that the fillet can be tangent to both surfaces. There is no reason the user should be expected to leave the filletsrf command start another command and pick a bunch of surfaces that may not even exist. That’s an absurd workaround to get Rhino to run the code that makes the surface All the information that is needed to create the correct surface is already there when the user picks the 2 surfaces that the fillet connects. There is absolutely no reason for the user to be asked to do anything at all.
You tell us the code has already been written that produces the correct surface but you are going to first make the user perform a complex chicken dance before you will run that code and produce the surface.
Do you think people aren’t going to complain?
If the intent of making this a test command is to test the code to see if it works properly, nobody objects to that. But if you think that a separate command is a an acceptable permanent substitute for actually fixing the failure bug that occurs inside FilletSrf when the user clicks on a surface with a same size fillet, that’s ridiculous.
Hi jim - A test command that is useful for some users making fillets between surfaces is being exposed as a real command, nothing more than that. This is not being done instead of incorporating the function into FilletSrf; that is simply not going to happen for V6 regardless of what happens to the test command.
I fully understand what you are intending to do. I’m trying to convince you to consider doing something far more useful instead.
It is obvious that statement is not true. We can see you have chosen to continue to allow filletSrf to fail instead of calling this function and producing the surface when the user asks for it.
You know filletEdge has this same bug. If the user selects edges that contain a same size fillet the filleting will fail. There is really no excuse for not fixing the bugs.
Don’t you think the users are getting weary of the pooh-poohing of suggestions to fix the bugs and instead being given tiresome workarounds?
sigh.
Here are some things that are not true-
Here is a thing that is true:
To the best of my knowledge, FilletSrf will not be changed at this point for V6.
Relevant Sub-fact: this is in no way related to what happens to the the test command.
For almost 20 years users have been working around this bug by either arranging it so that same size fillets never cross or by making their own spherical surface in places where same size fillets cross. Its really disheartening that these simple to fix bugs just keep going on and on and on.
Anyone can see that is what you have been doing. And I remain unpersuaded that filletsrf should not call this code
You said it would involve rewriting FillrtSrf. That is total nonsense. The only situation where this code would ever be called would be when FilletSrf is currently bailing out and sending the message to the command line that “FilletSrf is unable to create fillets”.
All that has to be done is run the code and produce the surface instead of sending that failure message to the command line. Any part of Filletsrf that is currently producing results would be completely unaffected. So there is really no change at all to those parts of filletsrf that are currently producing fillets.
Jim -
Hi-
I tried FILLETSRF on a CLOSED Polysurface cube. Clearly I’m doing something wrong ?
Thanks -
Chuck.
@cfee, this post is about _TestSphericalPatch
not _FilletSrf
. If you want to try it on a box, just run the command and pick the 3 faces of a box. It should give you a portion of a sphere surface as a result.
_
c.
Thanks, but didn’t work. Confident I selected 3 surfaces of a closed cube incorrectly (NOTcorrectly), but wasn’t successful.
I’ll keep trying.
Thanks -
-C.
Yeah, except that one of the early replies was about filletsrf, and was trying that as a possible workaround … .
Oh well.
Thanks -
C.
