Here some comments on Aviary Dashboard Control.
1> Toggle button is unreadable or really too small and doesn’t seems to react to “Size format” (4k screen)
2> Dropdownlist show the selected item on the top of the list when open without change in color or stroke which seems to change the order of the list which is a bit confusing.
By the way Great work!! Looking forward for a more stable release! will keep adding bugs or comments if found during testing.
Best Regards
Just seeing these posts.
I have not tested for 4k screens, so thank you for making me aware of the issues.
Can you post a screen capture of the dropdown list issue, i dont quite understand that one.
Regarding the “Layouts” issue. Does it fix itself if you close and re open the file?
Can you post the grasshopper definition shown in the image above? I’d like to see if I can identify the issue.
Also, just out of curiosity, what OS are you working on?
Thanks
