Hi @andheum and @marcsyp, sorry for bothering, I’m experiencing a weird behavior on your awesome plugin Telepathy with the current Rhino release Version 8 SR11 (8.11.24254.15001, 2024-09-10) on Windows
whenever I Ctrl+C Ctrl+V a Telepaty Sender, the newborns do not automatically connect to their own receiver
the only way to have those connections to appear is to somehow rename either one of the same senders or the receiver into itself, like deleting a character from the Parameter name and re-typing it back (enable/disabling any sender/receiver will produce no results)
brief video of the odd behavior:
I am not completely sure when that started happening, but my best guess is that it started on the very last Service Release
Until 10 minutes ago I had the Food4Rhino Telepathy version 1.0.0.0 dated 2017
I just updated Telepathy to the latest available version on PackageManager, V 1.0.1, but it did not solve the issue
at this point I’m also very curious if anyone else is having the same behavior, or if it’s just me ![]()
[edit] I’m adding more info as I’m doing some tests, still Windows + Rhino 8 SR11 (8.11.24254.15001, 2024-09-10) + Telepathy 1.0.1
when a file is saved, closed and reopened, all the Telepathy wires are working correctly even if they were not before (this is actually an awesome workaround at the moment
same machine, Windows + Rhino 7 SR37 (7.37.24107.15001, 2024-04-16) + Telepathy 1.0.1
all works as expected
System info
Rhino 8 SR11 2024-9-10 (Rhino 8, 8.11.24254.15001, Git hash:master @ d3c11108eae09fadc146928ba51b9b182a05303f)
License type: Commercial, build 2024-09-10
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Primary display and OpenGL: NVIDIA GeForce RTX 2080 (NVidia) Memory: 8GB, Driver date: 4-2-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.12
Primary OpenGL: NVIDIA GeForce RTX 2080 (NVidia) Memory: 8GB, Driver date: 4-2-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.12
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-2-2024
Driver Version: 31.0.15.5212
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24254.15001
C:\Users\innoi\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
