Tekla Live Link Pad Footing Reinforcement Number Type Problem
I try to create a Tekla component “Pad footing reinforcement” with grasshopper and I have one problem:
Rebar size in Tekla appear to be floating number (25.000) whereas in grasshopper it is integer (see pictures below). Tekla component does not work if rebar size is 25.000 so I need to change it manually to 25 in Tekla.
How could I convert integer number to Tekla component correctly?
Rebar Size is actually a String in Tekla, so change the UDA to TEXT and it will work just fine I reckon.
Thanks, I did not notice rebar size is a String in Tekla
