Tekla Livelink Footing
This Pad Footing component in Tekla Livelink actually create a Steel beam type in stead of a Pad footing type. Does anyone know how to have Pad Footing instead?
If you set the material to a Concrete Material it does create a Pad Footing, it has nothing to do with the Tekla Live Link.
Hi Oskar,
I tried this but it didn’t change anything
That’s good!
If you insert a Pad Footing manually in Tekla you can see that the Start Point (yellow) is at the bottom. In your picture it’s reversed which means that you need to flip the Curve and it will be recognized as a Pad.
This does the job! thanks heaps Oskar!
