some can tell me if it’s possible to assign the " %<element.tag>% " or other directly to the tag style?
Like this when i put a window or door and make tag it will give me the text automaticly.
Thank you very much
Thank you very much
Hi Hugues,
This is not possible now, but it’s planned in future versions. I’ll let you know when this feature is available.
-“Auto tag, when creating object”
-Changing default ‘Format’ of the tag object
would be great.
Hi @ahmet.unveren,
Do you mean that a Tag object (_vaTag) is created each time you insert a VisualARQ object? Or that VisualARQ objects get the Tag field automatically filled with a default value?
You can add a value for the Tag field while you are inserting VisualARQ objects:
Ok. We will consider setting the tag format by Tag Style properties.
@ahmet.unveren ok we will study this option.
Hi @ahmet.unveren and @hugues_tournier This is to inform you that in VisualARQ 3 it is possible to edit the information of tags by tag syle:
