Just installed the t splines add in. How do I access it from inside Rhino?
From page 15 of the manual :
- Type the command tsActivateLicense.
- Enter your Internet Activation Key
Also, if you don’t see the toolbar, use the Toolbar command and select T-Splines from the toolbar list.
Is this just a trial, Trevor?
Might be prudent to give Clayoo a whirl…
Thanks for the response. I have done the T-splines installation and entered the activation key but it is not showing up in the toolbar list.
Did the T-Splines menu appear in the menu bar? Are the ts command available?
Found it. I had two different icons for Rhino on my desktop [one was ‘Rhinoceros 5’ and the other was ‘Rhinoceros 5 (64-bit)’]. One must have been leftover from my trial version. When I opened Rhino from the '64-bit icon the t splines toolbars showed up.
