Synchronize Render Colors not working
Hello Rhino community,
I recently dug up an old project of mine and decided to do some renders. However, I realized that when I do the traditional “change layer display color and then SynchronizeRenderColors” for changing materials in the render engine (D5 fyi), the result is that most layers does not get applied the color and in D5 I only see two different colors (as you can see in the image only one layer got a new material color when the rest of the model layers clearly has different colors)
I noticed that when I SynchronizeRenderColor, the bar only indicates objects being synchronized instead of all the layers I’ve created which hasn’t happened in other projects.
Thanks in advance for any help!
Hi Ethan -
When I run SynchronizeRenderColor here, I always get a “x layers synchronized” message on the command line, never a “x objects synchronized” as in your image.
Please run the Rhino SystemInfo command and copy-paste the result here.
Dear Wim,
Thank you for the response and great catch, I’ve not noticed the object sync. situation for any of my other projects.
Here’s the requested info:
Rhino 7 SR34 2023-9-24 (Rhino 7, 7.34.23267.11001, Git hash:master @ a37d83041828484840f2448d5b3e3770e46694f9)
License type: Educational, build 2023-09-24
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Unplugged [84% battery remaining] ~38 minutes left
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 6-25-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 556.12
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-25-2024
Driver Version: 32.0.15.5612
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Users\ethan\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.12.0.0028\Rhino 7\D5Conv.rhp “D5 Sync for Rhino”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.34.23267.11001
Thanks again for the response!
Also a small update on the situation, when I clicked on “all layers” in “SynchronizeRenderColors”, it did apply the layer color to the material but the new property still doesn’t register in the render engine.
I’ve created new files and visited other projects and tried SynchronizeRenderColors and they work fine (layers synchronized and not object as seen in the image), and they work fine in the render engine.
It most likely is something I’ve fiddled with for this particular project or something wrong with the integrity of the objects.
Not sure if this was ever resolved, but a possible suggestion: In TwinMotion if you change materials in the Rhino model after fiddling with materials in TwinMotion, TwinMotion won’t update the fiddled-with material when synchronizing. The fix in TwinMotion is to delete whatever object has the material that has been adjusted in TwinMotion, then resynchronize the imported Rhino model.
