Synchronise Parallel View zoom level
Hi there,
I’m trying to figure out how to synchronise a left and front view so objects appear the same pixel size. This is useful for raytrace rendering with viewcapture to file.
I just zoomed on this object
And also the same object from a side view;
but they appear different sizes.
How can I make them the same zoom level?
Best,
Jeremy
Rhino has a one-shot command _SynchronizeViews which should make all the zoom levels the same in the parallel viewports.
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/synchronizeviews.htm?Highlight=sync
You can also toggle the use of linked viewports - in which case all parallel viewports zoom simultaneously at the same zoom level when you zoom in one of them. This is the macro:
'-_Options _View _LinkedViewports _Enter _Enter
The button is here:
LMB is '_SynchronizeViews, RMB is toggle linked viewports:
Wowww… Thank you so much… this is exactly what I wanted :slight_smile:
