Symmetry command
I am a beginner of rhino. I am using rhino WIP 6 in Windows 10. I am facing a problem with symmetry command. As per I know both symmetrical crvs or surfaces should change by altering either of the objects. However in my case it is not altering opposite object while changing one.
Any guidance!
Hello - like all History enabled commands (well, not ALL, dimensions are automatic) Symmetry pays attention to History recording being turned on by the user at some point before the command ends. If history is recorded then modifying the orignal object, the input, will cause the copy to update.
See Help on History.
Any luck?
