Hello, I have found a good video on using symmetry in Rhino:
However, I was wondering if there such a command as Rotational Symmetry? My building consists of two symmetrical parts, but one part is mirrored twice with regards to the other, ie it’s turned 180 degrees from the original. I need to be able to edit one surface, but see the result in both straightaway, as they depend on each other and should touch at some points.
Thank you
