Hello I installed Rhino 7 and I have the following problem, it does not show me what is drawn. For example when I draw a polyline, and confirm it with Enter, it disappears. If I select the area, it appears with a dotted line, but as soon as I deselect it, it does not show it to me. It happens to me with anything I draw. Could someone tell me what’s up?
Hello - Please run the SystemInfo command in Rhino and copy/paste the results here.
Rhino 7 SR11 2021-10-20 (Rhino 7, 7.11.21293.09001, Git hash:master @ 972ac562128b307e99f15e56dd11586c73e91ecb)
License type: Evaluation, revisión 2021-10-20
License details: Cloud Zoo
Expires on: 2022-01-18
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 8Gb)
Running on a virtual machine: VMware7,1
Computer platform: DESKTOP
Primary display: VMware SVGA 3D (VMware, Inc.) Memory: 0MB, Driver date: 5-18-2020 (M-D-Y).
> External USB display device with 8 adapter port(s)
Primary OpenGL: SVGA3D; build: RELEASE; LLVM;: VMware, Inc… OpenGL Ver: 4.1 (Compatibility Profile) Mesa 20.0.0-devel (git-392c167f32)
> No graphics device is being used for OpenGL
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.1 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: VMware, Inc.
Render version: 4.1
Shading Language: 4.10
Driver Date: 5-18-2020
Driver Version: 8.17.1.1
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.11.21293.9001
Is the color of the object you’re drawing set to bylayer and does your layer color match your background color by any chance?
I unchecked the GPU Tessellation option, and it worked fine !!! a lot of thanks!!!
Thank you.
it was GPU Tessellation option.
