This topic is a lengthy discussion about a problem I encountered with the Sweep2 component in GH Ver. 1.0.004. The strange result I got using the same basic GH code I used in earlier versions was both quite peculiar and confusing. But after fussing with different approaches I finally came up with one that worked:
The key to success (I think) is creating a sweep arc that spans the widest point between the 2 rail curves, and is also perpendicular to the 2 curves. Doing this is actually easy - just run the 2 curves through the Point on Curve component and vary it’s value so the 2 points end up on the rail curves at their widest point of separation. The attached GH file shows how I did this.
I don’t know how general this solution is, but I have retrofitted it on a couple of older GH files I have and it works OK.
PS: the new version of the Point on Curve component doesn’t seem to be editable except by sliding the thumb. It would be nice if double-clicking it allowed any desired value to be entered.
Sweep2Bug-bb3.gh (22.6 KB)
