Just wonder why can’t this sweep 2 work? It always mess up at the end of rail.
SWEEP 2.3dm (478.7 KB)
if you want the section remain in the same position at every point. you should use ExtrudeCrvAlongCrv
Hello - try this as a workaround:
ChangeDegree to 3 on the rail curves.
Place a copy of the section curve at each control point:
Loft the section curves with the ‘Loose’ style.
SWEEP 2LooseLoft.3dm (64.9 KB)
It would match your curves exactly if the curves were non-rational - all point weights = 1.
