How would I duplicate ReplaceBlock? Do I have to just delete it and replace?
Hi
The blocks in the model are called instance objects, and the underlying block definition is called instance definition. To replace a block you can use the method ReplaceInstanceObject in the object table.
Thanks!
This is my code that’s not working.
def SwapBlock(blockID):
NewBlockDef=sc.doc.InstanceDefinitions.Find("something")
OldBlock = rs.coercerhinoobject(blockID,True)
if sc.doc.Objects.ReplaceInstanceObject(OldBlock,NewBlockDef.Index):
return True
Okay I finally got this to work passing the guid, but an object reference should work too…??
NewBlockDef=sc.doc.InstanceDefinitions.Find("Thing")
if sc.doc.Objects.ReplaceInstanceObject(blockID,NewBlockDef.Index):
return True
