SVG Icon Editor issues
When attempting to modify a default button, this comes up:
Continue with what?
If I continue, I can edit the SVG.
And perhaps Save As, that could be useful.
The saved SVG has 0 bytes.
When I change the icon and give OK, I end up with this:
I think editing a default button should be forbidden at all.
Next try.
I copy a default button, Paste in this case, and want to modify it.
Then the same message comes up.
Is it intended that it is not possible to edit a copy of a default button?
When in the SVG Editor, I have 2 File menues:
When I edit a default button, the preview only shows the added paths:
The only possible tab is Properties:
If there is only this tab it is superflous.
Good morning @Charles,
The meaning was continue with editing. I’ll Update the message, thanks for this.
I’ve replicated this and it indeed seems to save only the additions, infact all the icons do. The SVG Editor should save out the existing icon with the edits.
It is not intentional, the SVG Spec is very very large and I’m currently working to capture enough of the spec to edit all of the Rhino icons but this is an ongoing process. When an item cannot be fully edited it is included as a background image for now. I’m doing a chunky update at the moment to capture gradients, defs, groups and other items.
That’s quite weird. Can you give me a system info I can add to this youtrack?
This is a bug I’m currently working to fix.
I’m working on more tabs, including a layers tab which will make grouping/ungrouping and changing the draw order easier. And ideally a tab for defs and reusable icon items.
Thankyou for the feedback and in depth bug reports. It’s really helpful!
Oh sorry, I forgot…
Rhino 8 SR11 2024-8-13 (Rhino 8, 8.11.24226.06001, Git hash:master @ bdb34e68e0160956fc5633ba163aeb8fe1301c50)
License type: Commercial, Build 2024-08-13
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 7-30-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.81
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-30-2024
Driver Version: 32.0.15.6081
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24226.6001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24226.6001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24226.6001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24226.6001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24226.6001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24226.6001
Fill color is not working. I am on a mac.
System Info:
Rhino 8 SR11 2024-8-20 (Rhino 8, 8.11.24233.01002, Git hash:master @ 6957666ece3a5f3ed7694c0ca66cdfea0407df3a)
License type: Commercial, build 2024-08-20
Apple macOS Version 14.6.1 (Build 23G93) (Physical RAM: 32GB)
Mac Model Identifier: MacBookPro15,1
Language: en-US (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Intel UHD Graphics 630 (1536 MB)
Radeon Pro 560X (4 GB)
LG HDR 4K (3840 x 2160 @ 30.00Hz)
GPU Vendor: AMD
USB devices
Generic: OWC Thunderbolt 3 Dock SD Card Reader
SanDisk: Portable SSD
Other World Computing: OWC Thunderbolt 3 Audio Device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
com.OWC.ThunderboltDockChargingSupport (1.2) A253F2D8-14AD-3A23-9D05-88B3FE1C67D0
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_glTF.rhp “Import glTF” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ShrinkWrap.rhp “ShrinkWrap” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_glTF.rhp “Export glTF” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_USD.rhp “Export USD” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_E57.rhp “E57 Import” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_modelio_macos.rhp “Model IO Import” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/MPlane.rhp “MPlane” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Squish.rhp “Squish” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_M.rhp “Import_M” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_X.rhp “X Import” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_STL.rhp “STL Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_STL.rhp “STL Import” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_Points.rhp “Points Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_X.rhp “X Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_Points.rhp “Points Import” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.11.24233.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.11.24233.1002
Happy cake day!
It doesn’t currently work before you select an item, and only when an item is selected. Youtrack here.
https://mcneel.myjetbrains.com/youtrack/issue/RH-82217
If it doesn’t work when selected, I will take another look at this
I can confirm it does not when selected.
I believe this is the issue → https://mcneel.myjetbrains.com/youtrack/issue/RH-82211
The colour is transparent by default. If you change the alpha slider along the bottom your colour will show.
I need to look into this particular dialog and see how easily this can be changed.
I overlooked the alpha slider. Sorry about that, but now I know. This a great improvement on the old editor. Great work. Thank you.
Thank you. Please report any issues, paper cuts or gripes you find, I want to keep improving it and its SVG spec support.
I have two problems with the creation or editing of icons:
-We can’t paste directly a bitmap. I have to copy the image I want, paste it in Affinity Designer, copy it from there, then paste it in the icon editor… cumbersome.
Sometimes I like to do tiny renders for icons. Before I just copied the viewport and pasted in the icon editor. Now there’s more steps and two other software involved (to screen capture and to copy to the clipboard in a compatible format)
-The editing tools don’t work at all. The square, ellipse, line, pencil… none works. See the video attached.
System info:
Rhino 8 SR10 2024-8-13 (Rhino 8, 8.10.24226.13001, Git hash:master @ c36ab43d576d4854b29b091b6b3a38e09decabf5)
License type: Commercial, build 2024-08-13
.NET 7.0.7
Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 5-6-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.41
Secondary graphics devices.
Intel(R) UHD Graphics 750 (Intel) Memory: 1GB, Driver date: 11-7-2023 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 5-6-2024
Driver Version: 31.0.15.5241
C:\Users\MarcGibeault\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\24.2.0.0\bella_rhino.rhp “Bella” 24.2.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.10.24226.13001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.10.24226.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.10.24226.13001
C:\Users\MarcGibeault\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.10.24226.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.10.24226.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.10.24226.13001
Hey @Marc this looks like the old editor to me. It has been replaced with this editor. (Thanks for the System Info, very handy)
The new one is default in 8.11.
The new editor allows import. But paste would be a good idea. I’ll add that to its features.
I installed the update this morning… I assumed it was the latest one that was ready to install.
How can it be that there’s no check when we finally say “yes” to install the update that it is the latest?
Edit:
What it this?
I have 8.10.24226.13001:
If I click on “Check Now…” the webpage says there’s a new build but it downloads the same one again…
You need to change the Update Frequency to “Service Release Candidate”
Here’s a better description of what to do
I won’t install a SRC (see the problem with Bella not working SRC 8.11 - Bella Fails to Load)
And the “Check Now” function should not tell me that a newer version is available and then goes on downloading the same one again…
There was a “hot-fix” for 8.10 which is why you got a file to download.
I believe the Bella issue in 8.11 is only on Mac, but that’s fine if you don’t want to use a release candidate.
No preview:
Even no preview when I add a rectangle or circle or something.
When I click the Save or Save As icon, nothing happens.
Except I get the file RhinoDotNetCrash.txt on the Desktop.
RhinoDotNetCrash.txt (2.7 KB)
Rhino 8 SR13 2024-10-8 (Rhino 8, 8.13.24282.10001, Git hash:master @ 7fc2e504d4c838aa0264b02fb10e24ecfff2824a)
License type: Commercial, Build 2024-10-08
.NET Framework 4.8.9277.0
Primary display and OpenGL: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 8-14-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.94
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 8-14-2024
Driver Version: 32.0.15.6094
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\XNurbs (80be33b0-13b2-4ac4-9c77-03829214f9e9)\5.1.1.3\XNurbsRhino.rhp “XNurbs”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.13.24282.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.13.24282.10001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.13.24282.10001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.13.24282.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.13.24282.10001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.13.24282.10001
Hey @Charles,
That seems very odd, and very annoying.
We’re struggling to reproduce this on our end, can you create a short video showing this, and ideally, also showing how the steps you took to open the editor and this icon.
Hi Callum
The toolbar is from madCAM, it holds SVG icons.
The effect is seen with the intrinsic Rhino toolbars as well, but only on the first attempt to edit.
Excellent, thanks @Charles I cannot repro this with the default rhino icons, but I can with the (?) icon in the MadCam toolbar! Excellent. I’ll create a ticket and look into this one.
I appreciate every issue you report, they make Rhino better and better :slight_smile:
P.s - Also figured out why File appears twice for you, so hoping to have that one resolved soon.
