I updated my plugin to export Curves, points, brep, … to svg. I will be happy to have some feedback. I modified some of the logic in order to be like PDF export or print.
Hi @laurent_delrieu are you still looking for feedback?
I was just playing with modifying SVG Icons from Rhino WIP, and your plugin looks helpful to export SVG files. As far as I know, it works the same in Rhino WIP and Rhino 6. I really like the preview and options.
I found some problems:
Z-oredering of the elements.
Original SVG Rhino icons are made in a way, that some elements overlap each other. I don’t want to modify geometry when it’s not needed, but overlapping elements doesn’t work as desired (even if they are spread out in the Z direction.
How it should look
Z order
How it looks - overlapping outline is being masked by other surfaces hence it’s not as thick as it should be
If I choose to overwrite the old file, but hit Cancel instead of Save, old file is gone and I’m left with nothing.
Currently I used points of radius=0 to force document size. Maybe some other method, or document size lines in the preview would be handy.
Could some process of batch exporting of SVGs be ported to the Grasshopper?
I didn’t know about it. I gave it a quick look and it seems like a great plugin.
I also had a little trouble with the ordering of shapes when they overlap. Is there any trick to overcome that?
I didnt look at the code for some times. The only order I care is the layers. Objects in layer are put in svg group. Svg group are rendered in order. Inside a group or layer i dont think there is a logic
Hello @Czaja feedback is always welcomed but I am far from Rhino and Grasshopper for some years I intend to come back when I will be retired (weeks or years ?).
As I will come back to laser cutting it will be the occasion to come back to SVG TOOLS.
Really appreciate your works and tools.
In the meantime, I got more familiar with Rhino native SVG export and when it comes to Grasshopper & SVG I recently discovered this absolutely fantastic GH plugin by David Mans
