Thanks for the workaround, but you realize that I’m extending in the V direction which is degree 1, and that doesn’t really need rebuilding?
Also, as I mentioned, with a little patience (and a lot of clicks), the surfaces do extend even without re-building, so Rhino is clearly capable of it. I’m crossing my fingers for them to fix this (since it does crop up quite a lot of times for me).
I mean, if they fix this… maybe there’s a glimmer of hope for extending open polysurfaces in the future (with chainedge)…
This is the complete thing I’m extending, and right now, it’s quite a number of operations for something that should be really simple:
Yes exactly
it’s the same problem.
I encounter this kind of problem often
… however I have noticed that this problem often occurs when the objects are too small
I don’t know if this has a relation to tolerance or not
Since it seems a problem in the weight of control point , tolerance - may be a problem not necessarily Rhino mathematics, can be a problem of the computer itself, the mathematical coprocessor.
