Surface won't array along curve
Hi, greetings!
i am trying to array this seat onto the rails beneath such that it follow the path of the curve.
Something like this(which i did manually)
But what i am getting with ‘arraycrv’ commands is this-
Any help is very much aappreciated fgrty.3dm (723.4 KB)
Thanks!!
hi ankit
i had no problems getting arraycrv to work, if i started at the beginning of the curve, included some screen shots
the first one i started with the object in a similar place to yours, in the second one i started with the object at the base of the curve, may not be an answer but it might lead you to discover what you’re looking for
Morning,
Rail curve pulled out (Just for better view)
At both ends curve cut off (To the center of slat)
Then _ArrayCrv …
ACrv
hey michael, thanks
Now i understand what was causing my array to go wrong. Thanks again
Hi eddi,
Thanks so much for such detailed explanation. Now the array is going perfectly
more than welcome Ankit
