Surface u,v,normal and surface edge curve conflict
When i “dupedge” the surface edge, generated curve direction is not same as surface u direction.
is there a way to edit surface edge direction in rhino?
Thanks
you can use the dir command and flip the direction of the curve.
you can use the same command to edit the direction on the surface-
