This time I used curve network to create a surface, and later on tried insert knot and remove knot, move uvn to adjust the surface. However when i turned on curvature graph, it showed the isoparm is not in good shape, there is some “pointed region” indicated that it does not go smooth , but I smoothed the U direction points and looks even already. May I know why and how to fix? thanks
I rarely use rebuild at this stage as I think it is changing the shape out of my control and no more at the shape of guide curves, but I always stuck here and maybe it is the only way
honestly though imo, the curvature graphs don’t make very much sense because it seems like different smoothing techniques can make the graph look “worse”.
but here’s kinda what it looks like after messing around with the points a little bit:
i had to butcher the speed cause of the 20kb restriction
At the end of the little bit of time I put in the transformation, I did try to throw in a ‘fitsrf’ stage but rhino didn’t really let it work unless I used 0.01 tolerance so I just didn’t use it.
There’s still lots of improvements that could be done, but depending on design intent, the best thing might to be to break the srf back into a crv netwrk and renetwrk the srf at some point.
I highly recommend the ‘rebuild’ stage in many workflows, that I know of.
I think alot of users are used to dealing with all kinds of deviations anyways – imo.
so, the rebuilding technique imo is just simply another way to handle what’s going on.
plus you can always go back and forth from different scenarios.
some users like to do things like ‘fitsrf’ but I’m not a fan of that really, although it’s good to know sometimes if you really really want to simplify a srf as much as possible.
while I don’t like it cause the srf becomes more unpredictable afterwards when moving control points.
Maybe, in such cases, rather than performing time consuming CP gymnastics, the original shape should be revolved from a simple degree 6 single span curve, and then transformed to make it elliptical?
It depends on the tolerance. I want to simplify it as well if the simplified shape meet the tolerance…just like command “ fitsrf”.. It won’t simplify anything if shape changes are not accepted.
