I created divided surfaces by using Surface split.
The order of divided surfaces became a strange after I merged as shown in the image below.
I don’t know the reason.
Is there any way to prevent the mess or fix that ordering?
Here is my gh:
Changing surface order.gh (227.8 KB)
Thanks for your advice in advance!
The Point List seems to sort the points along X.
Look at path 0;0 at D1 it has 15 items, 2 at D2, at the end you have 17 items. Not a mess
What did you expect?
Hi.
Thanks.
I expected that the original Paths remain as before Merge.
So that I can see same Surfaces order.
Hi Kim,
Thanks a lot.
I see that making a same number of Path is a solution.
I learned another thing from you again.
