Most of the models I build require a 2mm wall thickness for plastic parts. I often need to rebuild broken Nurbs surfaces on the generated offset surfaces. Does anyone have effective solutions for quickly and accurately generating uniform wall thicknesses? Is there a better tool than offset surface? I am thinking of exporting my models out as solids and then shelling them out in a dedicated solid modeling software to get around this.
Be carful with fillets and complex transitions.
sometimes you can avoid problems by keeping the surfaces without fillets.
offset the sharp polysurface and add corresponding fillets after the offsetSrf.
I think you will find that your offset distance may be greater than the minimum radius of curvature.
This is a design fail and not easily resolved. (no push button solution)
The best method is design with the understanding that you will need to offset for the wall thickness. If you choose to use radii smaller than the offset distance for whatever reason, then your only recourse is a manual (time consuming) re-evaluation and reconstruction of surfaces where offset fails. This problem will exist in any dedicated solid modeling software.
Here is a less complex model. Offset Example.3dm (14.8 MB)
I tried using both offsetsrf and shell, but still came out with naked edges on the interior surface.
do you models need to have perfect numerical offsets or can they be what I refer to as a “wax” offset that is more like what you would get in the old days with sheetwax being applied to a mold to generate the surfaces for a cavity which would be then panographed into a block of billet.
if a wax offset would work, then shrinkwrap is your new best friend, grab the v8 wip and give it a try.
I try to design to near perfect numerical offset so the plastic cool uniformly inside the mold. How much thickness variance is possible I’m not entirely sure.
my guess: the rough edge Tolerance together with this nearly tangential corner is to much for _offsetSrf to handle within tolerances.
offsetting the single surfaces (explode the polysurface) will show the geometrical problems of the edge-Tolerance and nearly tangential corner:
(offset in red)
Ok, so if I need to model and offset in .01 tolerance all surfaces edges need to be at least tangential, or curve continuous, for the offset procedure to not break the interior surface?
i would claim that the edge-tolerance of your model should be one digit more precise to not run into problems.
you can query this with the command
_what
And somehow those 4-surface corners are causing problems if the surfaces eges are not tangential or close to document angle tolernace.
analyse with
_edgeContinuity
Ok, I can see how that could create naked edges in the offset. The input Nurbs have to be totally dialed in (within document tolerances) for the offset tool to function effectively. Thank You!
