Having trouble having my surface reflect on my rhino geometry. Any advice or assistance will be greatly appreciated.
Rondebosch common 1.gh (13.7 KB)
Rondebosch Common 2.zip (10.3 MB)
So firstly the hexagonal meshes are invalid, because you extrude them in the Y direction, when they should be extruded in the Z direction. Secondly, the target surface is not a surface but a mesh (which the Surface Morph component cannot accept)
You need to rebuild the target geometry as two nurbs surfaces, and then map the geometry to each one separately
Also, I suggest creating the hexagonal geometry on a surface that has the same dimensions as the target surface
