I have not been able to create a surface to join 2 cylinders in Rhino 7. I have listed what I have done so far below.
- I have drawn 2 concentric cylinders pointing up on the z axis.
- I have unrolled outer cylinder as a rectangle on the XY plane.
- I have drawn a polyline on the unrolled cylinder.
- I have placed the polyline on the outer cylinder using the flowalongsrf command.
- I have projected a copy of the polyline onto the inner cyliner using the Pull command.
- I have trimmed the bottom sections of both cylinders using the trim command.
- I have moved the polylines to the side of the trimmed cylinder surface.
- I have tried joining both cylinders with a smooth surface with the loft command and got a very complex resulting surface between the cylinders.
- I have tried joining both polylines with a smooth surface with the loft command and got a very complex resulting surface between the plines.
Can someone help? I can send the file that I have been working on but don’t know how.
