However I can’t seem to get it to work for some reason and I’m a bit stuck. I’m basically a beginner in grasshopper so I would appreciate any help I could get.
P.S. I found the “Countours” layer but still get the same error from SrfGrid. It looks like what you are trying to do is create a surface from the contour curves?
Hi everyone,
I am trying to create a surface basically using the same method. I initially used a regular shape for the bounding box on which I built the surface, but as pointed out at the beginning of this post I received the error null “1. A point in the grid is null. Fitting operation aborted”. So I tried to use an irregular shape so that the mesh could perfectly cover the surface but with no luck. Does anyone has an idea of where the issues is?
@Joseph_Oster I see why you don’t like duplicate posts now, I apologize again. Do you still want me to take down the other one now that it has a reply? If yes I’ll do so.
@corellaman for some weird reason, when I open the .gh file you gave me in R7, I end up with this:
I didn’t change anything… very weird.
I think my university still has computers with Rhino6 installed, I’ll search for one tomorrow to check if it is Rhino7 messing around with me.
@corellaman Upon further inspection, I noticed that the panel in the top right (the one linked to the “create Set” Node) shows 2 lines in my case (0 True; 1 False) in my case, whereas in your image there’s just one line (0 True). Maybe that’s an indication that R6 and R7 don’t quite work in the same way? Just guessing…
Anyway, as Joseph points out, distance-to-origin issue, whatever that means…
The work-around I had previously shared dealt with that to ‘bypass’ said issue.
Joseph’s contribution will leave you with less to deal with by fooling Rhino into thinking stuff is closer to 0,0,0. Grab that instead if you’re trying to stick to the ‘tutorial example’.
Regarding the R6 vs R7 issue, I copy-pasted all into R6 and saw no problems:
