Surface from curves question
Hello Everyone.
I’m having some issues with making surfaces from curves. I feel like I’m missing something on continuity/tangency of curves.
Here is a short video of my issues. And I’m attaching my 3DM file.
Test.3dm (1.1 MB)
Thanks in advance.
Not saying it’s a solution - plus I bet you’ve already delved into the diverse fun fillet scenarios with Rhino - however in my experience with things like this in the past, changing the tolerance, even before the sweep operation, can make it less bad.
Of course ignore this answer if you’re not allowed to change the tolerance in your project. I am sure more knowledgeable people will respond shortly :slight_smile:
Could you give it a try with NetworkSrf + FilletSrf ? fyi,
Test.3dm (1.1 MB)
one problem is the initial curve, a test you could do is the blendsrf with g1, currently I did a test in g2
Test-rev01.3dm (1.9 MB)
There are potentially many things to improve. Could you attach a Rhino 7 file?
Please upload a file with the input curves used for the surface.
Using the Refit rails option in Sweep2 may help.
https://www.food4rhino.com/en/app/convert3dm
Could help
Well, macOS Sequoia does not allow the UNIX executable to run via the terminal, not even when in admin mode. The instructions are also very obscure. Maybe someone can furnish a V7 version of the file above.
