I have two separate surfaces that I would like to be tangent along a common edge. The tangency on the ends is continues. How can I ensure tangency along the common edge?
Does MatchSrf help?
Initially, MatchSrf did not do the trick by itself. I discovered though that if a higher degree was introduced on the linear direction of the surfaces (was degree 1), MatchSrf worked very well. Thank you!
