Surface Branches!
Hi, I hope u do well.
I want to separate some surfaces to the specific Data Branches with “partition list command” But I cant manage it whatever approach I chose when I do the selection! I Showed what I want in the pictures I attached, and also I Uploaded the .gh file below!
thanks.
Surface Trees.gh (1.6 MB)
hi, to create a different branch of data for each group of surfaces, you can save some components by using Entwine:
note that the selection order of the initial items is mantained, so, unless each group of surfaces was selected carefully in a particular order (like: first top left surface, then top right surface, them bottom left surface… and so on for each of them) you might not get the final result you are expecting
edit || the following is the order by which the surface were selected:
