I have a number of split surfaces that represent the planes of wall panels. I need to export this into my analysis software, and I need to group the panels in a certain way for the analysis. The panels must be split as shown to avoid triangular meshes. I have sorted all the surfaces based on elevation, but I am not sure how to create each sub-group based on thier level.
Each panel or tree is split into multiple surfaces using horizontal lines. Some panels have doors, so those are also split using veritcal lines. I would like to group each level of the surfaces into a group. I believe the tree needs one more level for this, but I am not sure how to do this. In this case panel 2 is the main panel that causes the problem. In many cases I will have far more openings to deal with.
The current paths are structured as you see below.
I believe the tree structure should be like the image below:
tekla_shell-FORUM.gh (17.3 KB)
