Sunglasses Rhino7
Hello everyone, I installed sunglasses for Rhino7 and followed the installation :
  1. Download the last version of Sunglasses.gha from Food4Rhino.
  2. Make sure Sunglasses.gha is unlocked, right click > Properties > Unlock (if visible).
  3. Copy and paste it in the Grasshopper Libraries folder, usually: C:\Users<YourUser>\AppData\Roaming\Grasshopper\Libraries.
  4. Restart Rhinoceros and Grasshopper.
  5. Access from Grasshopper Toolbar > Display > Sunglasses.
I have done everything but I can’t see sunglasses when I go to Display… Could anyone help? Thank you in advance!
if you go in GH - File - Special Folders - Components Folder, do you see the file sunglasses.gha ?
Hello, yes I see the file there. But when I go to Display then I can’t see sunglasses…
Sunglasses automatically works, no need to activate by adding a separate component.
Add any component and zoom in on its inputs and outputs. You should also a tiny label above the component appear.
When you load Grasshopper, is there an error message in the command window ? (or history window for mac)
